Κατι με θυμιζει...
Ειναι δυνατον να εχει μικροτερες διαδρομες αναρτησης απο το 800 η την Africa?
Model: BMW F 800 GS
Year: 2009
Category: Enduro / offroad
Engine and transmission
Displacement: 798.00 ccm (48.69 cubic inches)
Engine type: Twin, four-stroke
Power: 84.48 HP (61.7 kW)) @ 7500 RPM
Torque: 83.00 Nm (8.5 kgf-m or 61.2 ft.lbs) @ 5750 RPM
Compression: 12.0:1
Bore x stroke: 82.0 x 75.6 mm (3.2 x 3.0 inches)
Valves per cylinder: 4
Fuel system: Injection. Electronic intake pipe injection / digital engine management (BMS-K)
Fuel control: Double Overhead Cams/Twin Cam (DOHC)
Cooling system: Liquid
Gearbox: 6-speed
Transmission type,
final drive: Chain
Clutch: Multiple-disc clutch in oil bath, mechanically operated
Fuel consumption: 3.80 litres/100 km (26.3 km/l or 61.90 mpg)
Chassis, suspension, brakes and wheels
Frame type: Tubular steel space frame, load-bearing engine
Rake (fork angle): 26.0°
Trail: 117 mm (4.6 inches)
Front suspension: Upside-down front fork, Ø 45 mm
Front wheel travel: 230 mm (9.1 inches)
Rear suspension: Cast aluminium dual swing arm, WAD strut (travel related damping), spring pre-load hydraulically adjustable (continuously variable) at handwheel, rebound damping adjustable
Rear wheel travel: 215 mm (8.5 inches)
Front tyre: 90/90-21
Rear tyre: 150/70-17
Front brakes: Double disc. Optional ABS
Front brakes diameter: 300 mm (11.8 inches)
Rear brakes: Single disc. Optional ABS
Rear brakes diameter: 265 mm (10.4 inches)
Physical measures and capacities
Dry weight: 185.0 kg (407.9 pounds)
Weight incl. oil, gas, etc: 207.0 kg (456.4 pounds)
Power/weight ratio: 0.4566 HP/kg
Seat height: 880 mm (34.6 inches) If adjustable, lowest setting.
Alternate seat height: 850 mm (33.5 inches) If adjustable, highest setting.
Overall height: 1,350 mm (53.1 inches)
Overall length: 2,320 mm (91.3 inches)
Overall width: 945 mm (37.2 inches)
Wheelbase: 1,578 mm (62.1 inches)
Fuel capacity: 16.00 litres (4.23 gallons)
Reserve fuel capacity: 4.00 litres (1.06 gallons)
