Τον Απρίλη η παρουσίαση η επίσημη στο Μαρόκο...μια μικρή υπενθύμιση τι ξέρουμε μέχρι τώρα για το Tenere 700...από επίσημα χείλη...
Q&A Yamaha Ténéré 700 - EICMA release Nov 5th
General
Q What is the aim/role of the Yamaha Ténéré 700?
A The Ténéré 700 is the perfect new generation 'go anywhere' machine: made to be strong on the road and in offroad conditions
Q Is the Ténére 700 a "Super Enduro" bike ?
A No it is much more versatile than that, it is a true Ténéré allrounder for road and offroad, for the true adventure seekers
Q What makes the Ténéré 700 strong for offroad riding?
A The lightness, slim body, ground clearance and suspension travel, balanced chassis, stand-up riding position, smooth engine, 21/18 inch spoke rims with Scorpion Rally STR tires, long straight seat, ABS kill-switch, rider protection
Q Was offroad the primary focus?
A There was an extra focus on the offroadability. Many bikes in the Adventure segment are not truly offroad capable but the target of the Ténéré 700 was to follow the Ténéré spirit
Q What makes the Ténéré 700 strong for road riding?
A It's smooth, torquefull, stable and comfortable for highway cruising speeds with very effective weather protection; and nimble and agile for narrow roads and urban areas
Q Should it be seen as the successor of Ténéré 660?
A In a way yes - although there are minimal technical similarities. The Ténéré 700 is a much more modern and mature machine - better than the 660 in every aspect
Q To what extend is the production unit similar to the T7 concept?
A Since the T7 concept model, many details are further developed and improved but based on the positive market feedback many aspects of the T7 are maintained
Q To what extend is the production unit similar to the World Raid proto?
A Following the positive evaluation and feedback from the World Raid, many aspects of the proto could be maintained or further refined
Specs related
Q Is the CP2 engine exactly the same as applied for the MT-07 ?
A Not 100% similar, the FI settings and final ratio are adapted for optimised Adventure usage
Q What is the weight ?
A Some specs will be released at the World Press Launch (Press Test) - but we can already reveil that it's 205 kg
Q What is the autonomy?
A With 16l fuel tank capacity, the autonomy is > 350km
Q How is the seat height / ground access?
A The seat height is 880mm and shape is developed to optimise ground access. A lower seat and suspension lowering kit will be available as well.
Q How can the ABS be switched off?
A For offroad usage it is possible to switch off ABS with the switch on the bottom of the instrument panel - when the bike is stationary
Q What is the purpose of the 'remote adjuster' for the rear shock?
A To modify the spring preload easily and on the go, for instance when taking a passenger or luggage or for offroad usage.
Q Is the skidplate standard?
A Yes the aluminum skidplate is standard
Q Why are there no engine modes and/or traction control?
A Following the true Ténéré philosophy, the Ténéré 700 technology is very pure and to ensure a strong affordability as well these features are not included
Q Does it really have Brembo brakes?
A The brake calipers are Brembo
Q What are the key technical features?
A • High-torque 689cc 4-stroke CP2 parallel-twin engine
• New lightweight double cradle tubular steel frame
• Slim, compact and ergonomic body and seat
• Aggressive rally-bred face with four LED headlights and two LED position lights
• Adjustable long-travel 43mm upside down forks with 210mm travel
• Remotely adjustable link-type rear suspension with 200mm travel
• Compact rally style cockpit with tapered handlebars
• 21-inch/18-inch lightweight spoked wheels with adventure tyres
• Slim long-range fuel tank with 16-litre capacity for 350km+ range
• Compact rally-style multi-function instruments
• Switchable ABS for on the fly adjustment
• Screen and handguards give good rider protection
Market / availability
Q What is Yamaha's main target customer ?
A 1. The sporty adventure rider that is looking for a bike with strong road and offroad capabilities to be able to go literally anywhere - and/or the customers who loves that image/style
2. The adventure tourer that is looking for a light and smooth globetrotter machine with high versatility
Q When will the Ténéré 700 be available?
A Second half of 2019, the exact month will be communicated during the World Press Launch (Press Test)
Q What is the retail price?
A The price will be announced during the World Press Launch (Press Test)
Press launch is in Morocco, April 2019.
Accessories
Q What accessories will be available?
A The range of accessories will be released during the World Press Launch, but the line-up will be wide to further optimise performance and convenience, such as:
Sporty examples: Akrapovic slip-on muffler, license plate holder, chain guard, chain guide, radiator protector, LED flashers, tank pad
Adventure Touring examples: Aluminum side cases, main stand, engine guard, fog light set, low seat, suspension lowering kit
