2014 Ural Gear-Up Review
Koive k9
Kavala
Panos
Bmw , vespa
2014 Ural Gear-Up Specifications
MSRP$15,999
Engine TypeOHV air-cooled opposed Twin
Engine Capacity749 cc
Bore x Stroke78mm x 78mm
Compression8.6:1
Fuel SystemEFI
Horsepower41 @ 5500 rpm
Torque42 ft-lbs @ 4300 rpm
Transmission4-speed plus reverse
ClutchDry, double disc
Final DriveShaft
Front SuspensionIMZ leading link fork
Rear SuspensionSachs hydraulic shock, preload adjustable
Front Brakes Four-piston fixed Brembo caliper with 295mm floating NG rotor
Rear Brakes HB big bore single piston integrated floating caliper with 256mm fixed NG rotor Sidecar brake: two-piston fixed Brembo caliper with 245mm floating NG rotor
Front Tire4.0×19
Rear Tire4.0×19
Seat Height32 inches
Ground Clearance6.8 inches
Dry Weight730 lbs
Fuel Capacity5.0 gal
ColorsAsphalt Gray, Sage Green, Battleship Blue
WarrantyTwo Years
Και ένα βιντεο φυσικα!
πηγη
http://www.motorcycle.com/manufacturer/2014-ural-gear-review-video.html
Αυτά είναι μοτεράκια για 20W-50;););):D:D:D:D
